Is CEL Code P1171 related to ETM Problems?
AP
Post by AP »
Got a 2000 VOLVO S70 GLT with 132K miles on it. All of a sudden the CEL came on with code P1171 (Fuel Adaption, Bank 1) and the car is idling very ruff and stalls sometimes when the engine is cold?
Could that be under the 10 year ETS Warranty?
LarryP
Post by LarryP »
P 1171 is probably not related to ETS. Check your vacuum hoses and air intake hoses for a leak.
LarryP
Post by LarryP »
Just did a Google search on your code and lots of folks had this code with a bad Mass Air Flow (MAF) sensor. Try unplugging the MAF connector and see if it cleans up the connector, or idles better with it unplugged. I think your car substitutes a default value when it's unplugged
DonWillson
Year and Model: 2000 V70XC
Post by DonWillson »
AP wrote:Got a 2000 VOLVO S70 GLT with 132K miles on it. All of a sudden the CEL came on with code P1171 (Fuel Adaption, Bank 1) and the car is idling very ruff and stalls sometimes when the engine is cold?
The mass air flow meter and the ETM both measure the air flow. The mass air flow meter actually measures the flow through it by a hot wire aneometer. The ETM by a 'look up' table that says something like, "if the throttle is 40 degrees open the air flow should be 30 cfm" If these do not agree then it can set a code. But which is the real problem. I would suspect the ETM. If you replace the MAF at your expense be sure to keep it so it can be replaced if it is not the problem.
Announcing my affiliation with XeMODeX, Inc. as Internet correspondent and consultant to Volvophiles needing help with failing ETMs. See http://FixYourETM.com. For the full history of this problem see http://VEXEDvolvo.org
AP
Post by AP »
I had my ETM for free at VOLVO and the CEL went out. I've been driving the car for 3 days now and the car runns smoother when the AC is on. Also the ruff idling disappeared with the upgrade. All good stuff for my car!
thanks for all the good info!
