1998 V70 leaking rear view mirror
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
I know it sounds like a joke, but after a hard rain this AM, when I got in the car and put it in reverse (slight shake from going into gear) a good bit of water leaked out of the rear view mirror and directly on the gearshift. I would say it was about a tablespoon worth of water, not just a few drops. Came right down the black post that goes up into the map light fixture. No sunroof on this car, or other holes in the roof. Windshield and seals seem tight. First time it's happened, and its certainly has rained before... any ideas?
Windshield seal. Run a bead of black goo, less is more, next time you have some dry days.
RTV sealant is what I used
- Has thanked: 2199 times
+1 on that. If you have a sunroof, it could also be the drains are blocked, but windshield is ore likely.
- 1312 Views
Last post by nickbw898
- 1015 Views
Last post by jimmy57
- 713 Views
Last post by E Showell
- 1239 Views
Last post by senornose
- 641 Views
Last post by Lucky_Seven
