98 V70 will eng/tranny A fit in body B?
850TurboTurtle
Year and Model: 96 850T, 05 S80T6
Has thanked: 12 times
Been thanked: 5 times
Post by 850TurboTurtle »
Should I be able to frankenstein these two V70s together?
Blown engine, but good body:
http://seattle.craigslist.org/see/cto/5156925418.html
Damaged body, good engine/tranny:
http://seattle.craigslist.org/see/cto/5112512743.html
What questions should I ask the owners to be [relatively] sure I can pull the engine tranny from the black donor car and drop it in the silver car?
Thanks,
Rick
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
To roughly answer your first question, you could. Here is the but, Car A is all wheel drive and a turbo, Car B is front wheel drive and no turbo. You would have to change wiring harness, computers, exhaust, and pull the rear drive shaft to make it work.
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
NO
Transmissions are different and probably the engines (turbo vs a non turbo)
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
You'd want a 2.4 LPT Turbo engine to fix the first car.
Skip the second car.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
It's technically possible but in reality a total nightmare to Frankenstein those two together, not worth the trouble.
I would personally stay away from AWD 98s, also not worth the trouble any more IMHO.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Why don't you replace head lamp,side lamp & bumper on running one?
Looks pretty good.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
+1 to Misha. New fender should be $50 in a junkyard if you can find one in the same paint color. Otherwise, whatever for the part plus $150-$200 to paint. The bumper cover you'll want to find in a junkyard -- it is a $600 ish part from Volco (but comes painted to match the car). Headlamp you would want to find in a junkyard since they are a couple hundred bucks from Volvo, side marker light is also junkyard fodder. With luck on the paint match and junkyard parts you could have the whole shooting match for $750, plus bumper cover ($100)(less near me, more if you have to paint it); $30 for headlamp; $25 for side marker, $50 for fender -- $955 all in with some luck finding the right color parts, plus taxes, tags & title, more if you can't find color-matching parts in a yard or from a private seller (more expensive).
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
850TurboTurtle
"Why don't you replace head lamp,side lamp & bumper on running one? "
This is looking like the best option. Thanks!
misha
Post by misha »
When i got a closer look...it seems that passenger's side wheel is moved a little towards the door.Check for suspension parts or axle damage.Looks like something is bent there.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
misha wrote:When i got a closer look...it seems that passenger's side wheel is moved a little towards the door.Check for suspension parts or axle damage.Looks like something is bent there.
Good catch!
Make sure the subframe isn't bent
'00 S70, '04 S60 and the never ending quest for Stage Zero
