2002 s60 idler tension pulley size different
Homebrand
Year and Model: 2002 s60 2.4T
Been thanked: 3 times
Post by Homebrand »
Hi all
Received a new tensioner pulley.
The size is slightly larger. Both width and diameter. However the hearing seating size is the same.
Internal size for bolt is the same.
Should it make any difference considering the tensioner is spring loaded?
Photos attached old on the left.
Thanks for advice.
Homebrand
Post by Homebrand »
Never mind.
It doesn't fit. It rubs the tensioner casing. Damnit!
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
This is what you need (and fits)
URO Parts 30637141P Belt Tensioner Pulley with NTN bearing https://www.amazon.com/dp/B0066QTRDS/re ... 2vbETHGQMV
Homebrand
Post by Homebrand »
Thanks Mike.
Turns out the alternator is making the rattling noise (it's not loose, it sounds like it's inside it)
Put the new serpentine belt on and used my neighbours stethoscope thingy to hear it properly.
Well, needed the new belt anyway, old one was cracking.
