Why do my dash lights do this?
Acjlarsen
Year and Model: 2000 volvo v70xc awd
Post by Acjlarsen »
All of a sudden this happens every time I start my car. I'm looking at selling it soon and this isn't a good first impression. What's going on with it. https://vimeo.com/137066939
Has thanked: 1610 times
Been thanked: 4065 times
That's the ECc control unit telling you it has stored a fault code.
You need a DICE to read it or a high end OBD scanner like the Autel 802
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Or just take it to a dealer for code readout.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Acjlarsen
Post by Acjlarsen »
My buddy has an OTC Genisys. Pretty high end, will that do it?
misha
Post by misha »
Try it,but i doubt that anything which is not a Volvo scan tool will access ECC.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Autel 802.will read..
Acjlarsen
Post by Acjlarsen »
I read another forum post that ECC error is often caused by grease getting splattered over the electrical board of the damper motor by the reduction gears inside its case. Where is the damper motor how do I get to it?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
For Christ's sake, you can't rest them, that a hard fault/code, you have something wrong with the climate system, it needs to be read at Volvo with the old scanner.
Is there away to hand out Snickers bars via web post??
:D
Op...raise the hood and check your cabin filter for crap grunge and leaves. If you get enough stuff in the recirc door the motor can't move it and you get the flashing lights.
You can also remove the glove box and confirm operation of the recirc door by watching the arm move.
Acjlarsen
Post by Acjlarsen »
One snickers for you! [CHOCOLATE BAR][CHOCOLATE BAR] will check later. Thanks
