hi guys,
i just got my first 98 s70 T5... i am getting a P0303 code.. which cyl 3 misfire. seem to only happen
when driving WOT under high load like going up a hill. normal driving, doesn't throw the code, engine feels okay.
i changed the plugs... used volvo plug... still getting the code?
whats the next step should i change the wires?
or check distributor cap.
thanks
des
1998 s70 misfire cyl3 only on high load
Cap rotor wires
Compression test on cylinder 3
Did you gap the new plug to 0.028 inches?
- Year and Model: Many Volvos
- Been thanked: 76 times
At least check the ignition wire date codes and do a visual on the cap and rotor.
It could also be an injector that is getting dirty. You can listen to the injectors with a screwdriver and when they start to clog they will sound "duller" than the others.
If all of that checks OK then do a compression test. It could be a valve starting to burn.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
99% it is a burned exhaust valve. I'd expect significantly lower compression on #3 than the others. That's what sent my first engine to a viking funeral.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 1643 Views
Last post by AD_NAPCO
- 3303 Views
Last post by rguzz
- 7785 Views
Last post by silverslug98
- 11 Replies
- 3251 Views
Last post by traudesa
- 1765 Views
Last post by aewoodhouse
