I have a persistent P0455 error showing up a day or so after I reset it with my OBD app. I did a smoke test with my homemade smoke machine and found some smoke coming out of part #11, the tank's air vent filter attached to the filler hose. See attached diagram. based on my reading on the "Theory of Evap System Operation",I suspect the check valve, part #8, between the gas tank and filler neck might be leaking. What do you think? Does the air vent filter have a check valve itself?
Diagram of tank and evap assembly.
1998 V70 - Need Advice on P0455 Diagnosis
- Been thanked: 4068 times
Where is the smoke coming from on part 11? I don't think anything on that part should be open to air.
- 1573 Views
Last post by cvergi01
- 1548 Views
Last post by sleddriver
- 1368 Views
Last post by Miltown
- 36 Replies
- 12960 Views
- 1193 Views
