2011 XC60 A/C low pressure port
mohammedalqassar
Year and Model: XC60 2011
Post by mohammedalqassar »
The only port that I can locate is near the firewall on the passenger side right by the coolant tank, and it says 6nM (torque specs) on the cap but this seems to be the high pressure port when I trace it, and also because of the diameter (it's much bigger than the standard low pressure port diameter).
Does anyone know where is the low pressure port in the 2011 XC60?
Many thanks.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
You have to remove the plastic fasteners and lift the cowl/wiper linkage cover and you'll see it on the passenger side.
mohammedalqassar
Thanks Jimmy!
