As the title question:
I have a 1999 T5, can I replace the ETM with one from a turbo GLT? (HPT->LPT)
Or is that no good?
1999 S70 T5 - ETM interchangeable with one from a GLT
JRL
- Year and Model: Several
- Been thanked: 16 times
Probably
Turbo to turbo yes
Turbo to turbo yes
- Has thanked: 1611 times
- Been thanked: 4072 times
Please insert 10 AUS into the slot in your computer...
precopster
- Year and Model: Lots
- Been thanked: 128 times
Vida/Dice will tell you. If you've plugged the replacement into the donor loom press Update Configuration when entering the Diagnostics section. In Communication- Network see the 2 x software part numbers after highlighting the ETM icon.
Of course if you don't have Vida you might get lucky anyway.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
So the numbers should match huh?precopster wrote:Vida/Dice will tell you. If you've plugged the replacement into the donor loom press Update Configuration when entering the Diagnostics section. In Communication- Network see the 2 x software part numbers after highlighting the ETM icon.
Doesnt seem so with the ETM I just put in. Car seems to drive fine though and it passes the etm test with a deviation of 1.3 degrees.
Is there anyway to tell from the sw nr if it is LPT or HPT?
BMW 540i 2002
S70 Base 2000
- RigsPGT
- Year and Model: Red 99 S70 T5,
- Been thanked: 2 times
I've replaced mine with a yellow sticker which I bought it off Ebay and have the same part numbers and the car runs fine. I too couldn't find any info as to what model and year it came from. I was just happy to work and on top of that the unit was rebuilt last year
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
doublebug
- Year and Model: XC90 2007 D5
- Been thanked: 7 times
kallekula, that number says that you have latest sw version.
So if donor car is turbo and had also updated sw it will fit if from same MY or CAN config is the same.
If you have questions about Volvo firmware ask me. I may know an answer
- 2284 Views
Last post by nickelghandi
- 487 Views
Last post by Cookeh
- 19 Replies
- 4980 Views
- 1714 Views
Last post by precopster
- 36 Replies
- 2483 Views
Last post by ericmci
