A word on clogged Camshaft Solenoid
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I replaced my intake solenoid because it was clogged - much the same way the transmission solenoids were affected. The actuator was still working but the sleeve inside wouldn't fully open. There is a new redesigned solenoid part. This solved the following issues
- poor engine timing caused by the solenoid not fully opening
- engine pinging (pre-ignition) under acceleration even with higher gas octane and the cylinders being clean with new spark plugs
- top of the engine getting overly hot as a consequence of the pre-ignition (the temperature gauge will stay at 12h)
The pictures in order
1. Location of the solenoid (exhaust one pictured)
2. Newer design of solenoid. It has a stainless screw that won't rust like in the older design
3. Old design of solenoid with a rusted screw head
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Compare to clean solenoid passages on 2002 V70 (same engine) 3 years ago, at 124k miles then. Engine was running on Amsoil synthetic for couple of years, some crappy oil and long OCI before that - first short oil drains were like a tar, plus the VVT hub managed to die.
oragex
Post by oragex »
Looks clean indeed, no varnish at all
