2002 volvo v70 clicking sound when I start the car
mountain73
Year and Model: volvo v70 2002
Has thanked: 3 times
Post by mountain73 »
The car has 145,000 miles on it, and it has recently began to have a little trouble starting the engine. When I turn the ignition key, there is a clicking sound and a return to a no start, after repeating a few times the car will eventually turn over,start, and drive like normal. Could this be a problem with the solenoid or battery?
KSUMMEY
Year and Model: 2001 S60 T5
Post by KSUMMEY »
First test turn key on and move shifter from park to lowest possible place about 20 times see if car starts then back to park or if it will start from neutral. The transmission range sensor (netural safety switch) is known to create starting issues.
Another possibility may be a failing starter the clicking may be the starter solenoid.
Before replacing the starter grab a friend pop the plastic cover off the starter solenoid and have someone try to start the car when its giving issues. If you have power on the little wire and a click with no start the starter is bad, If you have a clicking sound and no power to the starter little wire you have a possible range sensor issue.
95 850 n/a 2002 S60 2.4t parted out
96 850T (sold) at 450K miles
98 S70 (sold)
99 S70 T5m (sold)
99 S70 GLT (sold)
01 S60 T5
01 S60 2.4t
06 XC90
Has thanked: 1610 times
Been thanked: 4069 times
Battery is first suspect - how old is it?
The neutral safety switch and the ignition switch are the next things to look at on old/high mileage cars.
mountain73
Thank you, simple as replacing the battery, gotta keep the wires and terminals clean and battery charged. aloha
MVSCORE!!!
(i only put these up the 1:100 times Im right)
GBS
Year and Model: XC70 2003, V70 2002
Post by GBS »
excellent, I've always wondered why the car can't inform the driver that battery is not holding a charge, similar to the alternator error when it stops working. I would expect the car could know the battery isn't holding charge way before it gets to the clicking start point.... I've been there done that with my 02 V70 as well.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
GBS wrote:... I would expect the car could know the battery isn't holding charge way before it gets to the clicking start point....
Yes, I've been developing a small upgrade to the ECM and DIM firmware that will inform the operator that the battery is old.
Caution: The code is Microsoft-based, so the DIM message will read:
"Battery is dieing...
Attempting START...
ARE YOU SURE?"
:lol:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
GBS
Post by GBS »
I like! Maybe while making it Microsoft based, get the driver to turn key to start to shut off again, works well in windows.... though shutoff is a "setting" now I suppose :)
regent
Post by regent »
Battery is DYING... (not dieing)
Sorry, syntax error...
My Bad Code :(
2015 BMW 335i
No doubt you would turn the car off by selecting the START button, too.
