I just replaced both rear shocks and mounts because I heard a loud clunking sound whenever I'd pull out of the driveway or go over a pot hole.
The sounds was coming from the rear/passenger side, so I assumed it was the mount. Replaced that first, still heard it, so I did both shocks and mounts.
I still hear it. I've ruled out tires being out of balance since it happens each time I leave the driveway. Im just not sure where else to check. Could it be the spring?
Mind you, this car is 270,000 miles old... any help would be appreciated.
1994 850 - New rear shocks & mounts, same sounds
- firestarterpro
- Year and Model: 850 NA - 1995
- Has thanked: 2 times
._____________,
||------|---||---||__\ \___
\=-(@)-===-(@)-=*B
The proudest owner of a Naturally Aspired 2.4L Volvo 850 Wagon of 1995!!!
94 850 NA Wagon was hit and totalled at 350k
96 850 NA Sedan sold at 180k
95 850 Turbo Wagon sold at 260k for parts
95 850 NA Wagon sold at 220K
\=-(@)-===-(@)-=*B
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If the clunk is loud, I would check the spring (it may break at any place from top to bottom) and for a broken real suspension arm. If the noise is not that loud, perhaps the handbrake cable is not well attached all along or the gas filler pipe got loose.
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
Trailing arm bushings and perhaps trailing arm mounts...or all four!
Here's a bad trailing arm bushing,
'00 S70, '04 S60 and the never ending quest for Stage Zero
- Has thanked: 2199 times
Does the 94 have a rear anti-sway bar? If so, check the bushings there also.
- RussB
scot850 wrote:Does the 94 have a rear anti-sway bar? If so, check the bushings there also.
Rear anti-sway bars do not have bushings
Good point! I had a look at Vida as I had more time, and I see there are no bushings on the 850 rear anti-sway bar. Long time since I was under one!
- Year and Model: Many Volvos
- Been thanked: 76 times
I'm with RussB. End links and/or bushings are the likely source of the noise.
they are talking about the rear passive trailing arm bushing and the insert endlink. At 270k, these are suspect. I have read a few DIY here on MVS, but it looks tedious. I drove an 850 with over 460k on the clock, and the rears were out, owner just kept driving as this is a crazy hard job to do IMO (noobie). You can check the status of the bushing by just looking at the rear without even removing wheel. If you lift the rear end, with wheels hanging, this will flex the passive suspension and you will see the condition of the aforementioned components easier.
Don't forget to use the rear jacking point (where the spare tire goes), with the hook attached. I have been using this as a jacking point and really like it. (need a big jack though)
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
Are these the same as 'delta links' on the later P80s?
There are lots of threads on delta links, and, yes, they are a pain to deal with.
MVS rents the delta link press out tool, although many have gotten them out with creative methods including burning them out with a torch.
(Mine crumbled and fell out of the car when I unbolted them...PTL...)
- 23 Replies
- 6477 Views
- 1607 Views
Last post by MyS40T4
- 2347 Views
Last post by CIK7
- 1423 Views
- 933 Views
Last post by rob2volvos
