I was looking through this forum to get me a clear picture on how to perform the PCV system service for my V70. The links I found for the process are very good and meticulous. What I am not clear, is as what parts to get before starting the job? Somewhere I read I would only need to get the oil trap beforehand, but on other places the suggestion was to get the kit from a place like FCP. So what is the best to be prepared for this job?
Thanks a lot.
Pat
1998 V70 2,3l PCV system service
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
You will need an intake manifold gasket, the hoses from the Breather Box to the block (x2), probably the hoses in the foam wrap, a clean breather box, probably the hose to the cam cover, and clamps. and an o-ring for the dipstick tube. The manifold gasket and o-ring are have to haves, the others will most likely be needed. Also see the CN90's thread about 5/8" hose for high mileage engines.
Current Volvos:
It might be best to first remove everything and get a good idea of what you need and don't need. For example, my breather box was able to be re-used, but I was missing major hoses. (and stuck with a 50$ breather box I did not need) Pull manifold and take a look at what you really need, otherwise youll be buying a lot of stuff and will have things left over. the NA is much easier. You might get away with not doing the full PCV if you fix the vacumme elbow on the left side of intake if that's what has ruined your negative pressure.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- 895 Views
Last post by southofmotown
- 1943 Views
Last post by psamanni
- 861 Views
Last post by aartzer
- 51 Replies
- 9036 Views
Last post by erikv11
- 1049 Views
Last post by rspi
