1995 850 engine cranks but won't turn over
I can't figure out why my '95 850 non-turbo won't start. I just replaced the plugs (Volvo-brand) dist. cap & rotor (Bosch) and plug wires (Bosch). I also replaced all the motor mounts/torque rod because they were all collapsed. The fuel pump is working because I'm getting a fuel smell @ the engine bay area each time I try to start it (actually I'm flooding it, I know). I took each plug out and checked for spark which I do have (I placed each plug one-at-a-time on the engine while plugged into the respective wire). I even replaced the camshaft pos. sensor with a used but known good one. The engine just cranks but won't turn over. It ran fine yesterday, nothing out of the ordinary happened. I also pro-actively replaced the ignition coil (Bosch) today since the one in there is 20 years old. Thinking it may be defective, I swapped the old one back in - still nothing. What am I missing?
- Been thanked: 4063 times
Try a 1-2 second shot of ether ( starting fluid) into the air cleaner and see if you get some fire
This gives you a clear indicator of spark vs fuel problem.
A compression test is the next step after that.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
and don't totally freak at the thought of compression test, it was running before, right? Lookup "lawnmower syndrome" here and see what is suggested. But spark, fuel, and compression are what a car needs to run.
Another thing to check is to double-check spark plug wire order, one of the manuals has it wrong. Check database for that under basic tune-up. Might check that first, no-cost, simple.
Current Volvos:
- Year and Model: Many Volvos
- Been thanked: 76 times
As said, the Haynes manual has the plug wire locations totally wrong and even the Volvo factory manual has the rotation backwards. If you look carefully on the cap the cylinder associated with each of the ports is molded into the plastic but the numbers are very small.
- 1713 Views
Last post by FLXC90
- 2041 Views
Last post by Agrector
- 1271 Views
Last post by mountaincarjunkie
- 4289 Views
Last post by ellis2311
- 4368 Views
