p80 cooling bleed valve
Has thanked: 1610 times
Been thanked: 4068 times
Has anyone used the valve of the right side of the engine for bleeding or flushing the cooling system?
It looks robust but I haven't ever moved mine.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Never. Lower radiator hose to the radiator is easier to get to and less chance to break something.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 2203 times
Been thanked: 1852 times
I have and it helps for flushing the block, but don't go ape on it. It is brass. Soak in PB Blaster for a while and use a 6 point socket or wrench and easy does it. Any doubts, leave alone!
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
tryingbe wrote:Never. Lower radiator hose to the radiator is easier to get to and less chance to break something.
That's how I roll too
'00 S70, '04 S60 and the never ending quest for Stage Zero
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Yeah, but sometimes (rarely) you want to empty the block too, which the lower hose doesn't do. Like earlier this summer when I pulled an engine with the car inside the garage, wanted to minimize stray fluid spills. Or when you are trying to flush out as much as possible all at once etc.
