Hi,
I purchased 3 damper motors for the ECC off of eBay. They came from a pick and pull. Does anyone know if there is a marking indicating what year they are? If so, where is it located?
Not sure if the same motors are used in other later year models.
1996 850R Air Damper Motors
There is probably a plastic casting with month and year pressed into the part.
The Volvo part number will tell you all you need to know about compatibility though
- Has thanked: 2199 times
- Been thanked: 1851 times
The part # from 93 -98 are the same for sure as I used a spare from a 96 850 for each car (93 and 98). PArt numbers were different, but part was the same. The 98-00 had one with a different drive connector for the motor beside the steering wheel although the rest of the unit was the same.
- 3191 Views
Last post by mrbrian200
- 16 Replies
- 5097 Views
- 14 Replies
- 5661 Views
- 1184 Views
Last post by redc70
- 59 Replies
- 2060 Views
Last post by CoupeC70
