2004 S60 Electro manifold throttle module intake
GordonBlue
- Year and Model: S602004
I get a message on the message indicator saying Engine Power Reduced and the car wobbles to a halt or splutters . Its an intermittent problem and Volvo here in Chiang Mai Thailand are recommending a replacement at huge cost c. $800 US. Is there an alternative option to replacing this part? Most grateful for any advice.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Only the early 2001-2002 models were affected by the throttle issue, so your 2004 should not have the issue. However, the throttle still is prone to getting dirty which affects the movement of the butterfly valve (the round metal part that is flipping) . There are videos on Youtube about it . There is no need to remove it like in the video, only detach the air intake tube at the throttle and clean both sides of the valve.
volvobro
- Year and Model: 2004 S80 2.5T AWD
I went through the same problem with my s80 and I was convinced I needed to replace my throttle body (which was about $650) but it turns out it was only a loose/dirty connector. Before you spend the money, check the condition of the connector. If that doesn't solve the problem then clean it like oragex suggested.
2004 S80 2.5T AWD - First car, first Volvo.
Follow my progress to stage 1 here.
- 7144 Views
- 557 Views
Last post by jderimig
- 490 Views
- 2273 Views
Last post by yagger
- 1170 Views
Last post by precopster
