Hi,
I recently purchased some used damper motors since mine went bad. Since I do not want to go to the dealer, after installing the temperature damper motors, what do I need to do in terms of calibration? Is there some special program that needs to be run at a repair shop?
Thank you.
1996 850 Damper Motor Calibration
- Year and Model: Many Volvos
- Been thanked: 76 times
You can force it to calibrate if you want to build a DTC flash code reader but it should do it by itself if you drive it over 20 MPH for a few minutes and then leave the key on for over two minutes after you stop.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
An alternative is to align the rotary position of 'new' damper to the same angle as the old damper... I've done this a couple of times and it seems to work fine.
- Has thanked: 2196 times
- Been thanked: 1850 times
I don't have an 850 or any paperwork on one, but I seem to recall there was a damper calibration process, but perhaps it was only on the 93-95(?) that had the test system under the hood.
- 1154 Views
Last post by jreed
- 14 Replies
- 5642 Views
- 21 Replies
- 10519 Views
Last post by RickHaleParker
- 1456 Views
Last post by Acknar
- 3186 Views
