1996 855 cant read obd ?
Hi guys, i recently bought a 855 t5 and when i wanted just to check how obd1 is working when i want to read codes, i couldnt find a way to do it because the LED is not reacting when i press the button....what do you think it might be a problem ? Is it common thing?
you need to reach out to "mischa"...a contributor here who is also from Serbia. he will be your new friend
I cant help you with your issue, I thought 96 had obd2?
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Do you have an OBDII port under the coin tray?
If you do, then check out the tools and code readers forum, to see if you can't fashion your own OBD 1 blinky thing to use on that one instead. Your car is probably like mine, an M4.3, and they just pretend to have OBDII, for all intents and purposes...
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Found a "problem"
I checked VIN number and it was 2.5 10v stock so it was obd1 once and my engine is 2.0 turbo now, so, someone swaped engines in the past but did not swap under ashtray parts so i assume that there is an OBD2 connector under the plastic or should i follow some wires to check that?
- Has thanked: 316 times
- Been thanked: 531 times
Ah, that would make sense. Sounds to me like someone didn't connect everything properly.Chaki wrote:Found a "problem"
All vehicles in the U.S. 1996 and newer should be equipped with OBD-II.
Yes, but, car works, it was dynoed and it has 240hp with NA cams and remap and i drive it everyday so no problems for now, and also, it has LPG system whick works perfectly....just, now i have to find that Bond 007 obd connector
- misha
- Has thanked: 155 times
- Been thanked: 432 times
From late '95 and on ALL these cars are obdII.
'95 have both since it's transitional year.Obd I under the hood and ObdII port under the coin holder in the cabin.
These cars (850)are made from '91-'97.
Since you don't have obdII port under the coin holder....your car is in best case '94.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 512 Views
Last post by misha
- 1439 Views
Last post by theobviousfaker
- 3256 Views
Last post by Sommerfeldt
- 13 Replies
- 3717 Views
- 965 Views
Last post by kuuze
