P2 Air cleaner thermostat operation
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
How does it work, when does the little flap close the air flow from the exhaust and lets the outside air in?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Thermostat opens a vacuum port and the vacuum moves the door. The changeover to exhaust proximity air heating is at 5-8 C for most systems.
That is for your S60. Some use direct thermostat motion to move the door but it is spring closed and t-stat has to expand to push door open. The direct version is very much prone to quit working and leave you with heated air that hurts warm weather performance and can kill the MAF.
- oragex
I looked at it and there is a thermostat, a spring, and also a small vacuum hose from the top of the air box. If I understand well, at temps above 5C the door for the exhaust air should remain closed?
- oragex
I removed this thing, the air box thermostat - not an easy job as the whole air filter box has to come out. Thrown it in hot water and in the freezer and it doesn't seem to move much. Time for a new one.
- oragex
Yes, there is a thin hose attached to the cover that keeps the thing in the picture in place
- oragex
Removed the stat. It expands 1/8" when in hot water
- Been thanked: 4069 times
I changed title to reflect P2 Air cleaner content..
Alldata had no info on this, so great that this is in the reference section
- oragex
Got trough this, permanently removed the thermostat.
When the s-stat fails, the engine gets continuously warm air from the exhaust, which doesn't help combustion. It might be a reason for low mpg so this fix hopefully helps increasing the mpg
Here's a short video
- 2251 Views
Last post by volvolugnut
- 1126 Views
Last post by crisnumbertwo
- 16 Replies
- 2171 Views
Last post by Marty27
- 26 Replies
- 4050 Views
Last post by DARK_BLU
- 15 Replies
- 8440 Views
Last post by Jewl1215
