Airbag reset before installation?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Haven't seen any other threads about this, and I'm not really sure what to do. I bought my V70 with damage to the front end, and the airbags had deployed. The SRS light is on, of course, but is there anything that I should do before installing my new airbags? Of course disconnect the battery, but is there some kind of module that needs to be reset so they don't set back off as soon as I hook up the battery again?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
New territory for me as I have never had a car with a deployed airbag but I would speculate (inspires confidence, doesn't it!) you just put them in and go. I think the code is either set during the discharge or more likely, when the ECU finds out they are deployed and not intact.
People replace dashboards and steering wheels (including airbag components) all the time, without messing with the SRS module. No reason why a deployed airbag should be different.
Has thanked: 1609 times
Been thanked: 4065 times
You will need a tool or dealer visit to reset the SRS light of course. A battery disconnect won't do it.
Post by erikv11 »
abscate wrote:You will need a tool or dealer visit to reset the SRS light of course. A battery disconnect won't do it.
Dealer will probably gouge you for the reset. Tool options include VOL-FCR or a high end scan tool like Autel EU702 Maxiscan or whatever Autel abscate has.
bmdubya1198
Alright, I figured as much. I just replaced the steering wheel and dash with airbags. Haven't reconnected the battery yet (got the car running, waiting for it to cool down because my fan won't turn on), but if my only problem is going to be the SRS light, I can deal with that. I'll probably end up getting a scan tool soon. Still need to get one for my Bimmer.
I got the Autel 802 real cheap but I think the 600 series will do Volvo and Bimmer.
I just clear my X3 faults and it had about 11 of them. Have to drive it for a bit and see what's real.
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
You need the relays I was pointing out on mine, for the fan to work properly. Don't over heat the engine before you get the fan working right. I have the grey plug and the other two plugs from my '98. Don't know how bad the wires were damaged, but the one plug was gone.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
bmdubya1198
obayha wrote:You need the relays I was pointing out on mine, for the fan to work properly. Don't over heat the engine before you get the fan working right. I have the grey plug and the other two plugs from my '98. Don't know how bad the wires were damaged, but the one plug was gone.
Shane
Yeah, I need to get the relays. I'm not going to run it until I get that taken care of.
Now, my transmission seems to be in limp mode. Don't know what to do about getting it out of limp mode. I'll either post about that in my build thread or start a new one. No need to take this thread any more off-topic than it already is.
Blockpartie
Year and Model: ...
Post by Blockpartie »
Seatbelts in the front have to be replaced as well. I'd recommend replacing the belt catches / locks also as they have subject to crash forces. Unless of course there was nobody driving or the seatbelts weren't used than the catches will be fine.
bmdubya1198
Blockpartie wrote:Seatbelts in the front have to be replaced as well. I'd recommend replacing the belt catches / locks also as they have subject to crash forces. Unless of course there was nobody driving or the seatbelts weren't used than the catches will be fine.
Yeah, my seatbelts are all locked up. The front ones are, at least.
