1992 240 Automatic engine will start out fine. After awhile (10 minutes or so) the car looses power, sputters and will run very rough. Eventually the engine may even itself out. Most of the time it takes stopping the car turning off the engine and letting it sit for awhile. When the car is restarted, giving it very little gas at acceleration seems to help, almost as if it needs to catch up. Repeat process until I eventually reach my destination. Fuel filter replaced. Air filter replaced. Mass Airflow Sensor cleaned (no codes). Spark Plugs and wires recently replaced. Recently ran fuel injector cleaner through it.
Any ideas???
1992 240 Intermittent Sputtering Engine
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
What more do you want?volvointenn wrote:Repeat process until I eventually reach my destination.
Ohm spec computer's block temp sensor....both sides of it...two circuits...place ohm meter's ground on engine block.
volvointenn
- Year and Model: 240 1992
Thank you for your reply. Are you suggesting I check the Knock Sensor or the IAT/Coolant Sensor?
- 93Regina
How the coolant temperature sensor worksvolvointenn wrote:Are you suggesting
1990 Volvo 240 Coolant Temp Sensor Replacement
Part Number: 1346030
volvointenn
Following Up - The remedy to this mystery appears to be a combination of several things...
1.) Replaced the coolant temp sensor
2.) Pulled in tank fuel pump. The pump was not connected to the rack. Reattached and tighted it down.
3.) Replaced the strainer to the in tank fuel pump. It had a massive hole in the end.
Glad to say all is well and running fine. Thank you for your input and suggestions!
-Norm
-Norm
- 12 Replies
- 3407 Views
Last post by deadmerelda
- 654 Views
Last post by RogueWave
- 32 Replies
- 6457 Views
Last post by nc940turbo
- 2069 Views
Last post by Bren
- 20 Replies
- 11934 Views
Last post by wooshybum
