2005 S60 Timing Belt replacement price
I recently got a quote for a timing belt kit, water pump, and drive belt replacement from a mechanic I use normally. The quote was for a little over $800. I am used to the cost for an 850 or a S70, but that just seemed really high to me. I know the S60 has to be adjusted for the proper belt tension, but does that make it so much more than a S70 or 850? I am going to get a few more quotes and see where they are. The odd part is the mechanic wouldn't come down any, or let me buy the parts to reduce his quote. He has never been like that before. I would also take any references for mechanics in the Knoxville, TN area. Thanks.
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
When replacing the water pump make sure it's either original Volvo or Aisin, as there are facts about aftermarket ones going bad quickly.
A good timing belt kit with water pump is around $150
http://www.ebay.com/itm/Engine-Timing-B ... c8&vxp=mtr
http://www.ebay.com/itm/Engine-Water-Pu ... c2&vxp=mtr
So he is adding $650 for a 2hours job with the coolant drain. There is no need to remove the crank pulley, so it's an 'easy' job for a mechanic.
I usually look up on local.google.com for any businesses and they have reviews from customers up there
- 20 Replies
- 17388 Views
Last post by Hurtfeelings
- 19 Replies
- 1731 Views
Last post by cn90
- 22 Replies
- 35807 Views
Last post by erikv11
- 5247 Views
Last post by jimmy57
- 23 Replies
- 17117 Views
Last post by jonesg
