Okay so I've been working on removing the head from my daughters 850. Some of you might remember helping me diagnose the burned valve a month ago.
I've followed Robert's (RSPI) instructions and I got all the way down to breaking the head free and I can't get it to budge. 7 of the exhaust manifold studs came all the way out leaving just 3 with the studs without nuts on them. I did remember to remove the coolant pipe screws from the passenger side back by the exhaust manifold. Come to think of it I didn't break the ex. manifold away from the head.
Could this be what is holding the head down and not letting it move at all? Or can they just be a bear to break free. Yes I did make sure that all of the head bolts were removed. Any hints then on breaking the manifold free?
Thanks Guys,
Shannon
1994 850 Turbo Idea's on getting head to break free
'96 855 NA 269,000
'94 854 Turbo 162,000 rebuilding the head after a burned valve
'95 854 Turbo parts car
'03 V70 XC 142,000
'04 V70 NA 230,000
'04 S60 NA 152,000 oldest daughter's car
2005 Mazda 5, 5sd 163,000
2001 Excursion 7.3 power stroke 135,000
'03 V70 XC 142,000
'04 V70 NA 230,000
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
With the manifold installed it would be difficult, but not impossible to break the head free of the block. But it wouldn't go anywhere upwards. After you remove the manifold, look for the tabs around the edge of the mating surfaces. The tabs are designed for a special pair of pliers to expand in the space between the tabs, prying the parts free. other methods are to pry but only in the same area, or to strike a drift on the upper pads (pretty much impossible in the car). Watch the videos again, noting what you have done, and see if there's anything else. That's the beauty of the medium, you can always look some more!
Current Volvos:
1ezliving4ume
- Year and Model: 850 glt turbo 1997
I'm in the middle of a turbo replacement and a head gasket job. I removed the head by unhooking the turbo from the manifold. Much easier than trying to unbolt the manifold from the head IMO.
When removing the head bolts apply heavy pressure to the bolts before just yanking on them. Does that make sense? I Broke one head bolt off, the back one between 3 and 4 piston and thought the block would be trash:( But as it turned out a hex shaped turn buckle fit right down in the hole and allowed me to drill first with a small dia. left hand bit and then with a little larger one and it backed right out! Prefect!
I got it off by removing the exhaust flange bolts and the turbo nuts. I don't think any of that had been removed since it was made 20 years ago. They were really really tight. Now just save some pennies for the next couple of weeks to buy all the parts that I want to replace since I'm already torn into the engine this far. I already have the PCV kit and I just ordered the head gasket kit. Thanks everyone for there thoughts. I'm sure I'll have more questions when I go putting everything back on.
Shannon
Shannon
'96 855 NA 269,000
'03 V70 XC 142,000
'04 V70 NA 230,000
'03 V70 XC 142,000
'04 V70 NA 230,000
- 17 Replies
- 10328 Views
Last post by volvolugnut
- 2307 Views
- 815 Views
Last post by matthew1
- 17 Replies
- 2891 Views
Last post by Klausc
- 2807 Views
Last post by mkc1
