currently driving as front wheel drive (front u-joint on the drive shaft need to be replaced).
has oil leaking some where under the top engine mount close to PCV or Turbo.
started having symptom similar to what people describe as ETM/MAF sensor failure.
rpm goes up & down around 2 to 300rpm while running or idling.
no code
Cleaned MAP and ETM with no difference.
What should I check?
