2004 S60R Angle Gear Collar Sleeve Removal
Finally removed the angle gear/differential from the transmission. Now to the dreaded removal of the collar sleeve. I can not get the sleeve to pull out of the transmission. Are there any tips on how to remove the sleeve without cutting holes to use a puller etc?
JRL
- Year and Model: Several
- Been thanked: 16 times
Not really, you have to do what you have to do to get it out... (one way or another)!
I was afraid of that suggestion. I have tried about everything minus heating it up with a propane torch. I have tried a gear puller after cutting notches in the collar sleeve, using an air hammer ratchet, to no avail. It will not move from the output shaft the least bit. I am running out of ideas as I do not want to damage the output shaft in any way. Also, I am afraid that the heat from the propane torch may damage something? Does anyone have any pictures or videos of their method in removing the collar sleeve? I am sort of past the point of no return since I have angle cut two grooves in the collar for removal.
The next step may be heating then rotating the puller to see if a combination of pulling/heat will break it loose. This is by far the most frustrating issue I have ever encountered while working on a car. I can't believe this thing is seized in the splines and pull not easily come out with a puller. I will have to give Volvo's engineering department a mark on this one.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Did you get it out yet? Im doing mine over the weekend
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- 16 Replies
- 4090 Views
Last post by Chili58
- 36 Replies
- 19001 Views
Last post by ggleavitt
- 602 Views
Last post by neilmullen
- 1782 Views
Last post by - Pete -
- 632 Views
Last post by darrylrobert
