It takes some fiddling to eventually get the key to turn. We have tried the 3 keys we have and they all will occasionally cause this problem. Does not happen every time, but is happening more frequently.
Am I looking at a dealer repair?
Thanks,
Clark
2001 S40 Ignition Key won't turn
http://www.instructables.com/id/Steerin ... Volvo-V40/
I may have answered my own question. A little time and some searching will do that sometimes. I found the above link for a 2004 wagon. I am hoping that the procedure will be the same.
Still questioning THIS failure tho. This problem is that the key will, on occasion, NOT TURN.
A similar problem on my 75 Porsche 914 but the key turned, it just did not activate the starter, or the fuel pump. And that was the electric portion of the ignition switch as in the link above. Different cars and parts could act differently, I guess.
Another similar issue was with my 04 Honda Odyssey. In this case the key would not turn.... again with some fiddling it turned and started the car. Took it to the dealer, for a RE-Keying. The mechanical tumbler portion had just worn out.
Anyone have any thoughts? test methods to try?
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Jiggle the steering wheel when trying to turn the key.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- alschnertz
Just came across the following repair.
1998 s70 glt ignition tumbler free fix
I realize it's not for an '01 S40, but maybe it's a similar set-up.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 11221 Views
Last post by RickHaleParker
- 1076 Views
Last post by erikv11
