Hello, should i be concerned that the canister was removed from my car? Looks like there are some lines disconnected where it used to sit (near the washer fluid reservoir from what i can tell) The hose to intake manifold is plugged, hose to gas tank is just disconnected inside the engine compartment.
Thanks!
Andrew
1974 164 Charcoal Cannister removed from car.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Evaporative Control System (Charcoal Canister)yukon922 wrote:canister was removed from my car
Myself, I'd buy a GM canister of similar design function and hook it back up. A pinch better fuel mileage will be the end result.
Kjet.org might have a volvo publication, but its rather simple in operation. "When the engine is at idle or is shut off, the charcoal canister absorbs and stores the vapors from... the tank... Throttling the engine causes the vapors to be drawn out of the canister into the air/fuel mixture bound for the engine. The vapors enter the engine through the intake manifold and are burned in the combustion chambers."
- 93Regina
I assume your 164 has a K-Jet setup, but I would consideryukon922 wrote:not even the bracket remains
GM 17064627 Vapor Charcoal Canister; GM says its a Discontinued Part (but there is another active part number: GM 17087209), and they list various vehicles that it came on....mainly 1984-85 vehicles....but, this ebay reseller shows it was used on 1,000 different vehicles from 1985-1989.
It has five ports, but the carb ports would be plugged off.
Later day canisters used electronic means to activate
Cross Interchange Parts
Factory Number
AIRTEX 4B1009
CARQUEST 73-10001
WELLS VC105
STANDARD MOTOR CP1004
STANDARD MOTOR PRODUCTS CP1004
GM 17087209
Alternate/OEM Part Number(s): 17058209, 17061005, 17061006, 17064623, 17064627, 17075822, 17075857, 17087209, 17113146, 215151, 21523, 21526, 21560, 2158, 53001850
yukon922
- Year and Model: 240-89'91'164-74'
Thanks so much for the recommendations, i saw them on Ebay also, ideally i just want a simple inexpensive one from that era. I am going to decide which one looks simplest and is cheapest and go from there. I noticed also that the newer ones all have electrical connections on them.
- 534 Views
Last post by rporzio
- 1061 Views
Last post by Mr. Detail
- 826 Views
- 1763 Views
Last post by 93Regina
- 2653 Views
Last post by BlackBart
