1993 940 oversize head gasket
bskeels
- Year and Model: 1997 Volvo 960
- Been thanked: 3 times
Does anyone make a .020 over head gasket for the B230FT? I haven't been able to locate one looking on most of the gasket manufacturer's sites (Victor Reinz, Fel-Pro, etc.) Can anyone help or can I use the head as is, had it machined .020. Thanka
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
precopster
- Year and Model: Lots
- Been thanked: 128 times
With .020 larger bores if the cylinder bores had been machined .020 larger then you would still use the standard head gasket.
I machined a Mitsubishi engine's bores to 0.030 and still used the standard head gasket for over 80,000kms before car was sold with no issues.
If you've machined a cylinder head 0.020 then you effectively have a SMALLER combustion chamber due to the eliptical shape being slightly reduced so I am rather confused by your post.
JDS60R
The head has area in it that show how low you can skim the head to make it level. As long as the head was cut above spec you are fine. 20 thou is a major cut. Normal is about 6 thou.
I'll try to find a pic of the cut markers.
Retired
JDS60R
Nothing on it here at work. Most of my 240 stuff is at home. I'll try to find it and post it if I do.
I thought I remembered a detent next to a port or a square block off to one end. Not sure. I will check - hopefully someone chimes in with the correct answer.
Your machinist should know for sure. You may want to ask him.
Retired
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Over at T-brick forum, John V, outside agitator , should know. That URL cited only works when logged into forum.bskeels wrote:Does anyone make a .020 over head gasket for the B230FT?
bskeels
just to clarify a little better, the head has been machined to .020, shop originally measured at .017 out, which according to Haynes and Alldata is acceptable, I had it machined to the max of 0.020 according to those specs. I searched Volvo dealers websites and a few gasket manufacturers and haven't found a oversized head gasket. I guess the next question is do I need one or is a standard one fine?
The Fleet
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Would it not be a critical issue if the motor is an interference type which some 940's are fitted with ?
Otherwise , as precopster stated above you would merely have a lessor volume in the combustion chambers but no risk of the valves contacting the top of the pistons.
see this link. http://www.aa1car.com/library/timing_be ... ngines.htm
list below is pasted from the link.
VOLVO
1993-98 2.3L 5-cylinder C70 S70 V70 850
1993-98 2.4L 5-cylinder 850 V70
1991-93 2.3L 5-cylinder 940 (Canadian)
1986-94 2.3L 4-cylinder 240 740 760 780 940
VOLVO
- 93Regina
Volvo has specs to how far down head can go; stay within that spec, everything is OK.difflock54 wrote:Would it not be a critical issue if the motor is an interference type...
Once exceeded, if timing belt slips, the valves will kiss the pistons.
However, I don't know when valves will hit pistons when Head is shaved too much.
I've got a B230F engine overhaul book, but I think the spec can be found elsewhere.
- 963 Views
Last post by Jonesroad
- 530 Views
Last post by volvolugnut
- 18 Replies
- 5813 Views
- 467 Views
Last post by erikv11
- 2472 Views
Last post by 1Matthias
