folks please help i have a s80 1999 the os indicator stays on permanatley even when you take the key out only way to sort is take fuse out. everything else works including ns indicators . i tried removing fuses 21,22,23 but didnt work but then not sure of correct procedure ie engine on or off - ignition on or off etc.
can anyone help as at moment hav fuse out so no indicators
thanks
s80 turn signal
abdomar528
- Year and Model: S80 T6 2001
- Been thanked: 2 times
Hello buddy,
I have a very similar problem with my car. There are times when I put the indicator on and it doesn't work. Then it double clicks faster than normal then cuts off again. I think I know how to fix this.
Pretty much what you gotta do is dismantle the indicator assembly and clean out all the grease. Then reassemble it with some new electric contact grease. You can get some from autozone or homedepot.
What has happened is over time the wear of the metal parts have mixed into the grease making the grease conductive. The current will travel places its not supossed to which results in making the indicator stay on or intermittently work.
Try this and post back.
Your suffering electrical problems just like me but a little different.
If this doesn't work, look for a relay if there is one. Replace it as it may be jammed. This should do it. I will try this too and post back.
