94 850 Spark Plug Nipple
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
So I had a bonehead move this weekend, I am doing an RN swap and decided to change plugs on the new engine that is laying on the floor, I pulled the plug opened the plug box and the damn nipple fell into the plug hole !!!!!!!!!!!!!! My father- old school guy says don't worry it will go out the exhaust and it is made of soft aluminum. I tried to get it out by poking around with a stick with bluetack on it but no dice. I really don't want to pull the head but am pretty much resigned to it. So is it necessary ?
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Tip the engine upside down and shake it?
'00 S70, '04 S60 and the never ending quest for Stage Zero
skloon
Post by skloon »
RussB wrote:Tip the engine upside down and shake it?
That was my brothers idea too- it may be hard on the hoist
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Make some ghetto vacuum tubing + shop vac.
BUT: empty the shopvac completely and cleaned it.
This way when you suck it out, you can see it in the shop vac.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Are the manifolds off? If so maybe a different angle with the stick stuff? Maybe an inspection camera in the plug hole while you fish? (or vacuum)
Current Volvos:
renns
Year and Model: 2005 XC70
Been thanked: 6 times
Post by renns »
I'd go with cn90's idea of the shop vac. Make sure an intake or exhaust valve is open on that cylinder so you get lots of airflow. I'd sure be hesitant to fire it up knowing there's that slug of loose aluminum in there. The chances of it jamming in squish zone, or holding a valve open are pretty high.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
Has thanked: 1611 times
Been thanked: 4072 times
cn90 wrote:Make some ghetto vacuum tubing + shop vac.
Get that cylinder on top dead center so that the valves are closed before you vacuum.
The other option is to buy/rent/borrow a fiber scope and see if you can grab it with either a grabber or chewing gum on a stick..
I can loan you the fiber scope, PM me - Ill also be in Buffalo in a couple weeks...not too far.
renns
Post by renns »
Just be careful advancing towards TDC. You might pinch that thing in the squish area (suitably named!). Of course, maybe you'll push it right up to where you can see it in the plug hole as well, if today's your lucky day.
skloon
Post by skloon »
We got it out !!!!- I turned till the intake valves were open and blew it out with an air hose- it popped right out- thanks for all the suggestions- now I just have a bazillion things left to do
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
Sorry for sounding like a newb, but what is a "Spark plug nipple"?
I've been shade tree wrenching on cars for over 35 years and never heard of a "spark plug nipple".
You must be talking about the tip that screws on to the top of the insulator, yes?
Glad you got it out. I wouldn't want, or even expect, the engine to push it out on its own.
'84 Prelude
'06 MPV
'13 Ford Focus SE
