04 C70 Transmission disengages when hot
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Anyone ever have this. Car runs fine for about 5 +/- miles. Once the transmission gets hot the transmission seems to shut down and car wont engage. Like a default safety to neutural. Wont move! not foward and not reverse. Dealer says it needs a new transmission. Thinking about doing the DIY transmission swap or DIY new valve bodys but don't want to burn the calories if it can be solved by far less drastic measures. Drain & fill and Seafoam Trans-tune have not helped. Any tricks or advice is welcome. Only problem is when HOT.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
precopster
- Year and Model: Lots
- Been thanked: 128 times
Is there a transmission code or CEL?? If not I doubt you can solve this without a rebuild.
Hook Vida up to the car and read transmission fluid temperature. As you may know there is a fluid temperature sensor on the valve body. If it's reporting incorrectly or faulty the TCM may have a limp home mode for an overheat situation. The fluid temp sensor is on the upper right area of the valve body.
The overheat may actually be true due to something wrong in the transmission where binding is occurring. Changing the fluid temp sensor may solve if there is no issue.
cuhfs
No code on my OBDII reader. Dont have the fancy VIDA reader but thinking about getting the china knockoff. Seems like no matter what I will have to get into transmission to fix it.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
So Rich, she's running again after a head rebuild or engine swap?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
There's an outfit called VBX that will do a valve body exchange with guarantee for about $600. I believe they are here in Jersey as well.
'95 855 auto (sold)
'95 855 auto (sold)
cuhfs
Yes. all good now. Sweet car. This transmission problem is on another one same model, I got in the mean time...
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
precopster / Mike - I PM you on this.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Closing this loop. Tried a valve body swap and it did not fix. Probably needs a rebuild.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 20 Replies
- 678 Views
Last post by cn90
- 568 Views
Last post by fic
- 13 Replies
- 4171 Views
Last post by June
- 17 Replies
- 4323 Views
Last post by villagepc
- 48 Replies
- 10936 Views
Last post by bmdubya1198
