Hi Guys,
I am still having some trouble ironing out the issues with my recently purchased XC70 (118,000Km).
Symptoms: (diagnosis with a cheap ODBII Bluetooth dongle and Torque app on Android)
Boost appears to spike at 14psi+ for a fraction of a second
Boost then was about 2psi tapering off to 0.5psi then back into vacuum
Performance feels like a non-turbo car
This to me sounded like a faulty TCV, so I replaced the TCV and the yellow and blue hoses with gear from IPD. (Red one looks a bit tricky).
Post TCV Symptoms:
Boost appears to spike at 12+ often, but not always.
Boost then drops to 3psi and seems to stay.
Car is certainly more responsive
Other rare symptoms:
"Reduced Engine Performance" light has come on 3 times in the last 2 weeks under light throttle. Removing foot from the accelerator made the light go out and not re-appear?
My diagnosis:
The old TCV valve was not functioning correctly, some previous mechanic has over tightened the wastegate to compensate, then the TCV has degraded more.
Proposed fix:
Turn the wastegate actuator BACK 3 complete turns and retest.
Unfortunately I cant get the parts required to build a wastegate adjustment tool at a reasonable price. So I am considering the guess and check.
Questions:
1) Do you think that this is a reasonable fix?
2) What boost level should I see?
Thanks in advance.
m
2002 XC70 Overboost then underboost?
waffleshill
- Year and Model: 2004 V70R, 2006 XC70
5-8psi max. 14PSI is a lot of boost for an XC70. Are you sure the TCV is connected properly? I wouldn't play guess and check with the WG. If you have access to VIDA scan it with it.
2004 V70R Mystic Silver Metallic/Nordkap M66 287,000 miles
positive that I have connected the TCV correctly.
The spike value could be off as the ODBII reader has a bit of lag in it, so it is not as relaible as a real gague.
I have seen the spike over 20, but I dont think the stock turbo could do that, so I have put it down to a quirk of the reader and app.
- 248 Views
Last post by jreed
- 346 Views
- 1681 Views
Last post by mountaincarjunkie
- 3980 Views
Last post by hansenjg
- 763 Views
Last post by doublebug
