P80 valve stem seal kit 7mm 272424 for 20 seals
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
This post is just a heads-up to Volvo part number 272424. It is a kit that contains 24 valve stem seals.
The valve stem seals on these engines are a known failure point, and more and more people are replacing them either just because it is time or while doing head gasket jobs or other repairs. It has also become abundantly clear that most aftermarket valve stem seals are of dismal quality compared to the ones sold by Volvo, and fail quickly. The trouble is, the Volvo ones are something like three times as costly when bought individually. You need 20 seals to do a 5 cylinder white block head, currently they run about $6 each. The kit is priced at $75.
Updated: cost is not about $90 e.g. https://parts.volvocarslisle.com/p/volv ... 72424.html
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Greetings. My local dealership seals this kit for $92.00 on line. Any thoughts or opinions on US Seals ? This is the brand that a WELL respected head rebuilder known to this sight uses ?
Post by erikv11 »
Greetings!
http://volvopartslisle.com/part/OEM-Vol ... 272424/Kit
$ 67.29 seal kit
$ 13.36 shipping
$ 80.65 to your doorstep
I just wouldn't mess with any other brand, even if it is what Clearwater or some other shop uses, unless I was absolutely certain. Many people have done this job, and then needed to do it again in less than a year due to leaking seals again. The OEM ones will last 15+ years, longer than almost any of us would ever need.
clifford06
Greetings. I agree with your insight. Thanks. Also, thanks for refreshing my memory about Volvo Lisle site. Their prices are great. Their shipping for my parts list is better than my local pickup plus taxes.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Now I am curious as to the procedure to replace valve seals without removing head.
How much time should people budget for?
https://sites.google.com/site/incarvalv ... placement/
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
cn90 wrote: So: is it necessary to remove the TB and sprockets?
Yes, the lifters are on top of the valves which will need to come up to gain access to the seals. You can leave the cam sprockets on the cams. No need to pull the belt all the way off, just pull the tensioner and take the belt off the sprockets.
Just paid $200 for a set of these seals. Box arrived today.
Post by erikv11 »
To clarify: These seals are not (and never were) $200 when you buy the complete set. That was a cost of buying separately instead of as a set. Currently $71 at the link above.
Has thanked: 1609 times
Been thanked: 4065 times
I can't imagine going through all that labour and then putting in a cheap rubber essential part.
Cry once.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
abscate wrote: 14 May 2018, 10:53
Cry once.
Agree.
85 GLH, 367 whp
00 Insight, 72 mpg
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
abscate wrote: 14 May 2018, 10:53 I can't imagine going through all that labour and then putting in a cheap rubber essential part.
Cry once.
Kind of like a rear main seal. I don't know why anyone would think it's a good idea to cheap out on something that takes so much work just to access.
