2005 non turbo VVT intake.
I am sure its listed and I swear I searched for hours but I cannot find VVT resetting info for the intake cam.
Son ignored the water pump bearing failure and belt popped off, bent valves.
I know I will need to reset valve lash by changing the buckets as needed, how best to retain cams for measuring purposes?
Can someone point me to instructions for starting from scratch timing with VVT on the intake, non spring.
Thank you in advance for any and all help!!!
2005 S60 2.4 need VVT and Valve lash help
- 901 Views
Last post by brunom
- 5201 Views
Last post by LT South Africa
- 4238 Views
Last post by jimmy57
- 429 Views
Last post by craiger
- 3336 Views
Last post by darrylrobert
