I had my MAF sensor replaced about 5 months ago because it was reading too rich and would not pass an inspection. It worked fine afterwards. I changed out my battery a week ago because the battery went dead after sitting for 4 months without running. I thought it was the fuel pump but a few codes came up when it was diagnosed at Autozone:
p0440
p0171
p0174
It may be possible that my MAF sensor is faulty, but I think there is a strong possibility that my 02 sensor is bad. I'm going to try to clean my MAF sensor first before jumping to the o2 sensor, since it is reading lean and it is cheap. I need a little advice/help if possible.
1999 Volvo s70 Possible MAF sensor issues
That P0400 code is an EGR problem.
A vacuum leak (either in EGR or other hose) will cause all those symptoms and code. Leave the MAF alone and find that leak first
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
Yes, vacuum leak. Leave the good parts alone and look closely at all vacuum and turbo lines and hoses
'00 S70, '04 S60 and the never ending quest for Stage Zero
Sorry I meant to put p0440 instead of p0400abscate wrote:That P0400 code is an EGR problem.
Thats an EVAP code - and...it will still give you a vacuum leak!!
Careful VAT ( visual, audible, tactile) inspection.
A smoke tester is the definitive way to find it.
Your EVAP stuff is in front of the right rear wheel, btw. Don't let the 1998 location fool you.
- 1547 Views
Last post by jwalker275
- 16 Replies
- 2749 Views
Last post by 93SCMax
- 745 Views
Last post by chrism
- 3115 Views
Last post by itsmekirby
- 1128 Views
Last post by wizechatmgr
