Hey everyone, I'm having a boost problem with my 98 s70 T5 auto(160k). When I floor it at about 25 mph I'll boost up till about 45-50mph, once It shifts into 4th there is no more boost.
Now when I floor it at about 40 mph I get no boost at all and the rpms move slowly. Also feels like my engine is bogging down a bit.
I've noticed my car has been getting harder to start over the course of the last month or so... taking a couple of seconds to start up. Sounds like its struggling to turn on. I never have to crank it more than once but its definitely taking longer( this is only on a cold start)
At this point I'm thinking it's my cbv and or fuel injectors. Can someone give me a little insight on this?
If it is my cbv, why would I be able to boost early on and then get absolutely no boost when I floor it at 40?
Thanks for your time everyone.
98 S70 T5 Boost problems- possible CBV?
captainkong
- Year and Model: 1998 s70 t5(auto)
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Likely a bad turbo tube.
captainkong
Thanks for the videos. I'll talk a look at my hoses after work tomorrow. I replaced some of the hoses by the engine with silicone, but haven't checked the one by the one by the turbo.
As for the cat, how would I go about determining if It is it? I haven't seen any threads about cat problems with the same symptoms as mine.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Unbolt the downpipe and take it off for a quick test drive.captainkong wrote: As for the cat, how would I go about determining if It is it? I haven't seen any threads about cat problems with the same symptoms as mine.
http://volvospeed.com/vs_forum/topic/17 ... heck-next/
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
1ezliving4ume
- Year and Model: 850 glt turbo 1997
The CBV is easy to check and it sounds as if that could be the problem. When I opened mine up the diaphragm was sucked in, not good
captainkong
I inspected ALL my hoses related to the turbo and intercooler and surprisingly nothing was torn or had damage...Only thing is I have some pretty rusty clamps down by the turbo.
After doing some more research it seems very likely it could be both my cat and cbv causing me problems. I'll attempt to remove the down pipe Wednesday when I have some time.
If I don't notice much of a difference in performance after I unbolt my downpipe would it be safe to say my problem lies with the cbv?
I will also post a video today/tomorrow showing how its acting. Hopefully that will give some better insight to my problem
thanks everyone.
thanks everyone.
- 1491 Views
Last post by wizechatmgr
- 356 Views
Last post by Vuym
- 11 Replies
- 1379 Views
Last post by erikv11
- 18 Replies
- 5009 Views
- 1914 Views
Last post by rguzz
