1996 850R Front Brake Squeal
wackenhut
Year and Model: 850R 1996
Post by wackenhut »
Hi,
My front brakes were making a squealing noise when coming to a stop. I discussed this with the mechanic and most of it has gone away. I think he might have lubricated the brake pads or shims. Anyhow, I still notice an occasional front brake squeal, usually when going at a very slow speed (taking foot off of brake pedal, and then slowly coming to a stop) or going in reverse and stopping. Does anyone know what could be causing this? The brakes are new and the rotors are in good shape.
Thank you.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Are the brake pads leading and trailing edge 90 degrees or beveled at 45 degrees. I've found that beveling the edges 45 degrees with a grinder did away with squeal. The unknown is the shape of the rotors which can make a contribution to squeal with out having them turned.
