99 V70XC PCV quick question
PatternFlyer
Year and Model: 99 V70 XC
Has thanked: 6 times
Been thanked: 7 times
Post by PatternFlyer »
I have a quick question to ask.
Just got the cheap PCV kit from IPDUSA. Part number 124569
It came with
5 black O-rings
4 washers with black plastic on inner edge
1 green O-ring
What are these for? Where do they go?
Should I use some kind of adhesive with the gasket?
Any idea?
I am trying to work on the car starting this evening.
Thanks,
Clockboy
Year and Model: 05 xc70, v70 2.5t 06
Has thanked: 2 times
Post by Clockboy »
I just did the 98 version and the hose is completely different. My guess is:
green washer - dipstick
4 washers - for banjo bolts
5 orings - fuel injectors.
My guess is you'll recognize them and figure out how they go as you disassemble.
PatternFlyer
dipstick? engine oil dip stick?'
Clockboy
Post by Clockboy »
Yes. Actually the dipstick tube where it enters the engine.
Clockboy
Post by Clockboy »
Has thanked: 1610 times
Been thanked: 4065 times
No adhesive on the intake manifold gasket
The metal can connector from the oil trap to the block may be different than the one on your car. I put mine rubber side against the oil trap, some did it the other way. My way is faster.
Getting the banjo bolt under the manifold aligned and in is tough work.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
abscate wrote:Getting the banjo bolt under the manifold aligned and in is tough work.
That may be the biggest understatement I have read in a while. :D
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Being old and feeble I've found removing the radiator fan opens up the underside of the manifold nicely.
If I did this job again on a 1999 I think I would pull the alternator to get better access
PatternFlyer
So farn i pulled the entire fan assembly after getting the tube that hooked up to the ETM.
got the air box out, but the tube netweek the turbo & airbox has a few hoses that are hard to take out.
does vadis show entire process including the long hose assembly from the front to the back?
not easy even after I did the PCV a few years ago. Can't remember how I did.
98 actually are not the same as 99. Vadis shows 99 as 98, so i am looking at it as 2000.
turbo control valve hoses will be replaces also.
hope I can finish today.
