My 850 has an intermittent horn. Sometimes it works for a moment, but most of the time it doesn't. The horn contacts inside the steering wheel are good. I even replaced two of them to be sure. After I replaced them it honked a few times then suddenly stopped again. The fuse is good. I'm not sure what to check next.
Note: I must mention that the instructions to replace horn contacts are really terrible. He leaves out the hardest part - removing the old contacts. I had to cut them off with a Dremel cutting wheel. He fails to provide photos or tips on this step.
1993 850 Intermittent Horn
Paul-93-850
- Year and Model: 1993 850 non-turbo
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Have you tried replacing the steering wheel?
Paul-93-850
How will replacing the steering wheel solve the problem? It's more likely a bad wire or connection.
It's your contact reel, or clockspring. https://www.matthewsvolvosite.com/forums/viewtopic.php?t=34639 Replacing really isn't hard at all. One thing to note, remove the right torx first when removing the steering wheel cover. Also, tighten the right side first when re-installing. Not sure why this matters but I think it may be why my horn stopped functioning reliably.
https://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=50993
1985 240 Turbo 310K | 1995 Yellow T5-R 236K | 1996 850 Turbo 225K | 2005 S40 2.4i 139K | 2005 XC90 2.5T 179K | 2007 S40 T5 141K
Paul-93-850
Ozark Lee posted
"The clock spring has nothing to do with the horn or the cruise control. It will trip a SRS error though."
http://volvoforums.com/forum/volvo-850- ... ing-35599/
Paul-93-850
Does anyone have instructions on attaching a secondary horn button to bypass the troubled original equipment?
Paul-93-850
I found the horn fix in an obscure post on http://www.volvoforums.org.uk/showthread.php?t=18549
"The cause of the horn not working is the earth wire on the steering wheel it is held in the body of the wheel under the airbag in a square hole with a brass clip . if you put a suitable sized self tapping screw in to wedge this tight it will solve the problem ... "
The British forum one-upped us. I fixed it for free using an old screw.
- 4079 Views
Last post by MazdaDude
- 759 Views
Last post by 95850glt
- 1294 Views
Last post by leucadiacruiser
- 1265 Views
Last post by Salomons Driveway
- 462 Views
Last post by 2forty
