Okay...still need some advice. I did the entire head rebuild (which wasn't as difficult as I feared.) got it all back together but the car won't fire. It turns freely (which means everything is lined up appropriately....thank God) it sputters one time and then stops cranking. It will also do something VERY odd. The starter will remain engaged and spinning the engine even after I release the key from "start" position. I can take my hand entirely off the key and it will still be trying to start the car. It started doing this when the gasket blew.
I did the "unlock-lock" thing and reset the immobilizer. Fuel Pressure seems good. I get no fire and this odd starting anomaly. Any thoughts?
2007 S40 No start after head gasket change
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Does the engine appear to turn over 'too freely'?
Maybe it is 'lawnmower syndrome'.
Try a teaspoon or so of oil in each cylinder with the plugs removed to help raise the compression.
There are many posts in the forum about lawnmower syndrome and its effects. Do a search to read up on it.
Craigd2599
I remember reading about that. Thank you!
Craig D
- 1105 Views
Last post by Craigd2599
- 1168 Views
Last post by mf70
- 1379 Views
Last post by kmaninaustin
- 16 Replies
- 3423 Views
- 30 Replies
- 4556 Views
Last post by FLXC90
