Still in Limp Mode
Florida Wheel
- Year and Model: S80 2000
Hey All. I have a 2000 S80 in limp home mode. No codes on OBD II. I've replaced the MAF sensor. Then took it to dealer. They scanned and said it was definitely the ETM. I sent the ETM to Xemodex for rebuild. Car is still in limp mode. Battery is good. It's actually worse after ETM rebuild as it will stall out now. Is there a computer reset that needs to be done? I had battery disconnected while reinstalling ETM. Any help would be appreciated.
Florida Wheel
1999 Ford F-250 SD PSD
1977 Olds 442
2000 Volvo S80
1977 Olds 442
2000 Volvo S80
volvobro
- Year and Model: 2004 S80 2.5T AWD
The computer resets after the battery has been disconnected for awhile. If xemodex failed to fix your etm then you should probably contact them. Get your car scanned again, if you're still stuck in limp mode then there must be a code associated to that.
2004 S80 2.5T AWD - First car, first Volvo.
Follow my progress to stage 1 here.
- 4327 Views
Last post by jonesg
- 1013 Views
Last post by ecnirp91
- 12 Replies
- 4561 Views
- 1050 Views
Last post by mechaman1
- 1664 Views
Last post by bmdubya1198
