Hey guys. 98 v70 awd 2.4 Im having issues with my AC system. I first thought it was the relay, after replacing it, i'm not having any luck. When I use a jumper the ac compressor clutch engages and blows cold. What would be the cause of no signal activating the relay?
Thanks
R
98 v70 AC relay not receiving power
wuttheheeck
- Year and Model: 98 v70 awd
- Year and Model: Many Volvos
- Been thanked: 76 times
Are you hot wiring directly to the compressor or jumpering the relay itself. If it works when you jumper the relay then it could be a bad controller. Is fuse 5 OK? Is there battery on the red wire at pin 1 of the relay?
wuttheheeck
Hey Lee thanks for the reply. all the fuses look intact that have to do with AC and temp control. I used a piece of wire and jumped the connections. An audible sound was heard as the compressor clutch engaged. I'm wondering if I have a leak in the system and a low pressure signal is stopping the compressor. Might get it looked at by a shop, seems over my head. Although the summer heat has ended, It is sure nice to have dry defrosting air when there's a fresh foot of snow on my car
Ozark Lee wrote:Are you hot wiring directly to the compressor or jumpering the relay itself. If it works when you jumper the relay then it could be a bad controller. Is fuse 5 OK? Is there battery on the red wire at pin 1 of the relay?
- 4390 Views
Last post by WA-Boater
- 1001 Views
Last post by ProjectS90
- 11 Replies
- 2795 Views
- 16 Replies
- 3057 Views
Last post by MRZero
- 1066 Views
Last post by misha
