I have no cabin heat. It has dual climate control. If I turn the temperature selector(s) from 64 > 84 and vice versa, I can hear what sounds like dampers moving. I was told the cabin climate temperature (fan) sender is potentially bad. Looking in the little vent I can see what looks like dust bunnies. How do I get the panel off to remove this sensor and check it over?
On a side note, in the overhead lights above dash, there is a similar little grille. What is that for?
I purchased a copy of VIDA 2014 from sleazebay that came in today, but the discs are junk (awaiting customer service response), otherwise I wouldn't be asking.
2005 S60 2.5T AWD - No cabin heat
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 3 times
Found information here on the site. Picked the lint ball ever-so-carefully out with a 1.4mm jewelers screwdriver, avoiding the thermistor. I'm sorry, but if you use a high-volume vacuum cleaner, you're asking for it to suck that puppy out. Not up for a $150 sender assy. We'll see tomorrow.
On the flip side, the previous owner had fine white hair and favored beige clothing.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
- 18 Replies
- 5271 Views
Last post by zanzabar
- 1787 Views
Last post by MarcM
- 1254 Views
Last post by doublebug
- 26 Replies
- 5487 Views
Last post by dejanaleksov
- 26 Replies
- 4246 Views
