I saw this in a for sale ad. I will not buy the car, but I was curious if people had thoughts on it:
"This car has an electrical or computer issue that causes it to stall when you press the brake pedal for the first five minutes of drive or until it warms up once it warms up it runs and drives just fine."
01 V70XC brake pedal causes stall when cold
- Has thanked: 311 times
- Been thanked: 817 times
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
My first guess would be a sizable vacuum leak in the brake booster. When the engine is cold and normally wants an enriched fuel mixture, it can't tolerate the additional air introduced by the vacuum leak. Once it's warmed up, it can handle the additional air.
My second guess would be the auxiliary vacuum pump isn't working (if 2001's had that pump).
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
When I bought mine the rpm was dropping at about 500rpm when coming to a stop. Went to clean the throttle body and the MAF wire and it went away. Not sure which one was the fix though.
If his rpm is also dropping a lot, the engine might stall.
- 1320 Views
Last post by Volvo S80
- 1677 Views
- 3522 Views
Last post by 93ForMe
- 15 Replies
- 7281 Views
Last post by firstv70volvo
- 600 Views
Last post by xHeart
