Recently, I noticed that negative battery cable had white color powder. I brushed it off with metal brush and cleaned negative battery terminal with battery cleaning tool. 1 day later, the white color powder appeared on the battery cable again. It looked like corrosion to me. This has never happened before in last 20 years. My battery was purchased from dealer back in 2008. There is no fluid around the negative battery terminal.
Is the battery leaking acid and cause corrosion on battery cable ? Is it time to get a new battery ?
Thanks.
Ching-Ho Cheng
1995 855 Negative battery cable corrosion
Salty sea air and old copper. It's not battery acid, it's just entropy.
7 years on a New England battery...well done !
- Has thanked: 311 times
- Been thanked: 817 times
It's almost certainly battery acid and the battery is almost certainly the problem. You can either seal around the post with something like dielectric grease and a battery pad, see if that slows it down, or get a new battery. I agree 7 years is pretty good life out of a battery.
It is possible that the battery is leaking because of overcharging, so keep an eye on the charging system. You don't want to kill a new $100 battery.
delete
