2006 Volvo XC90 2.5L
Occasional hesitation on hard acceleration.
Original problem started with stall on highway, no restart. Had vehicle towed. We diagnosed problem to the fuel pump. Replaced with OEM fuel pump. Ran fine at idle, stall under load. Swapped out PEM (with used part). No change. Checked fuel pressure.
While driving, occasionally the car would hesitate repeatedly on hard acceleration. Lots of power loss during episodes. On hard acceleration, might start out with good acceleration and then sputter, then good acceleration again. Seemed to do it more when engine was warm. Only does it when engine under load.
Replaced fuel pressure sensor (on fuel rail). No change. Replaced spark plugs. No change. Added Redline injector cleaner into the fuel tank. No change. Changed turbo control valve TCV. No change.
I'm stuck. Any ideas?
2006 XC90 Occasional Hesitation on Hard Acceration
batman00024
- Year and Model: 2006 XC90
I forgot to list that. Yes, I took off the throttle body and it was a little dirty. Cleaned it and still no change.
I've read this hesitation issue on a number of forums but no solutions.
batman00024
If I push it hard (lots of full acceleration) to recreate the hesitation, engine light comes on and I get code P0089 (fuel pressure). The hesitation is occasional and usually when engine is warm (not cold).
I've read forums of similar problems and haven't an a solution. Some people listed fuel pressure sensor or spark plugs as the fix, but I've done those and still no change.
batman00024
I did some testing today. I connected a obdII scanner that reads in real time. Problem seems to be fuel pressure related.
Fuel rail pressure at idle is 44psi and staying around that during normal operation. On more aggressive acceleration, the pressure drops instantly to 9psi. If I stay hard on the accelerator, the psi stays between 9psi and 15psi. If I remove my foot from the accelerator and quickly reapply pressure on the accelerator in a less aggressive manner, the fuel pressure instantly returned to 44psi.
When I experience the hesitation, the fuel pressure at the rail seems low (9psi- 15psi). This problem only happens when engine is under load. It will not happen when aggressively pressing on the accelerator with the vehicle in park.
The question is, what is causing the slow recovery of fuel pressure during aggressive acceleration?
robertshar
- Year and Model: XC90 2006
Have you tried changing the fuel filter? It could be partially blocked with fuel tank/gas pump debris.
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
+ 1 on the fuel filter, mine was so corroded it was leaking.
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
- 1432 Views
Last post by jreed
- 433 Views
Last post by br0dy519
- 1511 Views
Last post by FLXC90
- 343 Views
Last post by phils94850
- 4029 Views
