Okay...where do I start?
My mechanic recently replaced the Rack and Pinion on my 2001 Volvo V70 2.4T. My model apparently calls for the Non-Variable assist version of this rack according to the volvo dealer. The parts guy that my mechanic goes thru swore up and down to my mechanic that there was no actual difference between the two parts and that they both will work fine, claiming that the variable assist is just a "dummy sensor". My mechanic lined up both racks (the old and the new) and everything appeared to be identical. Once the rack was put back in however and the tie rods were put back in, he said that there is very little room for adjustment for the alignment, basically about 2 threads worth.
Today my mechanic said after further looking into this, they may have sent him a model 2000 and not 2001. So here is my question.
1) Is there ANY physical difference between the variable assist and non variable assist rack for 2001?
2) If this is the 2000 model of rack that is installed on my vehicle now, can this be fixed by replacing the inner or outer tie rods only, or do we need to send back the incorrect year rack and start from scratch with the right rack?
00-01 V70 Rack and Pinion compatibility questions
My experience with racks and pinions what the other way around my car had the assist on it but not the rack I put on the vehicle, which made the steering much harder to turn, not much noticeable after a while or if you never driven a volvo but a noticeable difference right after driving a different volvo
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
I'm finding myself in a similar predicament. I would prefer to save the money on a non steering assist rack. Any other compatibility issues I should worry about?Vovo_merz wrote:My experience with racks and pinions what the other way around my car had the assist on it but not the rack I put on the vehicle, which made the steering much harder to turn, not much noticeable after a while or if you never driven a volvo but a noticeable difference right after driving a different volvo
Danpaco
- 1220 Views
- 1300 Views
Last post by oragex
- 469 Views
Last post by stevolvos60
- 531 Views
Last post by j-dawg
- 1470 Views
