2005 xc70 seems to be sipping coolant
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mrscullini
Year and Model: 05 XC70, 08 XC70
Has thanked: 1 time
Post by mrscullini »
can't tell what is going on. i can't find evidence of a leak. knock on wood, i don't think it is a head gasket, cracked block or head. wondering if it might be some boil off through the cap gasket.
i seem to be using literally a couple tablespoons or so over a week or two. the only way i can tell is that i marked the recovery tank. wondering if i over filled and it is boiling off through an old gasket. the level has always remained below the high mark, even when hot. although it has been close.
any thoughts are appreciated.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Do a pressure test.
Boy, you really bought a winner here. I've never heard of one with so many issues all at once
mrscullini
Has thanked: 1 time
JRL wrote:Do a pressure test.
thanks. will have the system pressure tested.
btw, bought it from you about 4 1/2 years ago.
JRL
Post by JRL »
What happened?
Were you a bit lapse on maintenance or is it just your location?
mrscullini
Has thanked: 1 time
JRL wrote:What happened?
not sure, you delivered a great car. it has 154k on it, hoping to get another. i think most of the issues are just symptomatic of the vehicle,
axle ping- replaced axle bolts but still have the ping
dead aoc pump- replaced the pump, all is good
dead cem- sent to xemodex, all is good
most the recent issues were related to the cem.
most recently the leaking aoc filter cover is my fault. i should have replaced with the improved cover that came with the filter.
just hoping the coolant loss is not a head gasket or cylinder/head.
KurtL
Year and Model: V70R 2005
Been thanked: 5 times
Post by KurtL »
Had this a couple of times on my 2001 V70. Once was a small crack in the radiator and the other was a cracked expansion tank. Neither was very easy to see.
mrscullini
Has thanked: 1 time
KurtL wrote:Had this a couple of times on my 2001 V70. Once was a small crack in the radiator and the other was a cracked expansion tank. Neither was very easy to see.
thanks. years ago in my 2000 v70xc i had a small crack in the expansion chamber. i'll have to check this more closely.
Has thanked: 1505 times
Been thanked: 3817 times
Look for dry signs of coolant on all the hoses. It's very common for a small leak to dry before you find it!
I never found any leak on my 1999 but when I did every single hose, and there are nine of them, the usage of about 200ml per month stopped
mrscullini
Has thanked: 1 time
abscate wrote:Look for dry signs of coolant on all the hoses. It's very common for a small leak to dry before you find it!
thanks. i don't even think i'm losing that much.
it seems if i have an issue with a head gasket or head or cylinder i would be losing much more.
i've done a cursory check of the cooling lines. i'll have to give things a much closer look.
Don't forget heater core. You could have a really small seep which would give you a coolant smell in the car. Maybe. That job is a bitch on the 2005. Hope it's a hose.
