1996 850 1994/96 850 radiator swap
I have the ever popular side-tank crimp leak... Can a 1994 non-turbo radiator (new one) be swapped into a 1996 non-turbo? Do they both come out the same way, from the botton or, the '94 from the bottom and the '96 from the top?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If cars have the same transmission(auto or manual) they are the same and...yes,they comes out from the bottom.
Radiator from a car with auto transmission can be installed into car with manual,but radiator from manual transmission CAN'T be installed into a car with auto transmission.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
What misha said. If these 94 and 96 NAs have the same trans, then the radiators and their connections, brackets etc are identical.
The rads can go out the top or out the bottom, whichever you prefer, but yes you can do them both exactly the same way.
- Year and Model: Many Volvos
- Been thanked: 76 times
The N/A radiator is easier from the top in IMHO.
Be careful removing the mounting bolts. The captive nuts have a tendency to break loose and it is a half day job to cut the old bolts out. PB blaster the crap out of the mounting bolts the night before you start and it can help. The left side is usually the worst since battery acid works on the bolt over the years. Working the bolts back and forth as you remove them can also prevent them from binding.
I totally agree. Well with his whole post actually.Ozark Lee wrote:The N/A radiator is easier from the top in IMHO. ...
Thanks for the info but, I'm still a bit confused. Can the radiator core come out from the top on both cars or, do I need to put the '94 on ramps to take IT out from the bottom and the "96 doesn't need to be on ramps and IT comes out from the top? (both cars are non-turbo with automatic transmissions) I'll be sure to PB the mounting bolts.
Thanks for your help...
Chris
Maryland
Chris
Maryland
Those two cars are the same as far as pulling the radiator.
The rad can come out the top or the bottom. Top is easier, no ramps required unless you need them to get your bucket under the drain location.
- misha
To me....it was easier from the bottom,but i have access to a garage with built in channel.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 3555 Views
Last post by t3yf5g
- 7133 Views
Last post by jalwlb
- 105 Views
Last post by volvolugnut
- 816 Views
Last post by Teddy1975
- 947 Views
